Fitment tests - When I was searching the interwebs, I had a hard time finding some pictures. People would say they needed to do a lot of trimming or a little trimming, cutting some plastic, cutting some metal etc.
Here are some sample pics of a -25 Offset on 20x10 rims with leveling kit - 305/55/R20's (33.2")
Just about Full Lock - spacing is about 1/4"-3/8" in back
1/2 Turn on the wheel will show that front lower bumper will require small amount of trimming.
I made my cut about 1.5" up from the edge and made a subtle 4" arc to the inside edge. You can just cut a triangle if you wish. My dremel did it easily. I edged the path with masking tape. **Edit : After testing it forward / reverse while needing suspension travel I increased it to 2.25" from bottom edge.
*Use WIDE masking tape and a couple of layers if you do not have a steady hand. This will prevent you from scratching your painted lower bumper. I am still waiting on my new bumper so I will pre-cut it before painting & installation.
**Use your safety glasses whenever you are cutting ANYTHING.
