Finally some actual updates to share
epper:
I had been thinking about getting some led headlights for a while but just hadn't pulled the trigger yet. Well a bulb burn out on me Monday, so I promptly ordered these.
http://www.ebay.com/itm/141626728210
I opted to go with these since they have great reviews and they come with reverse polarity adapters and load capacitors in case you need them. I did end up needing the reverse polarity adapters. Here's some pics from install.
I got the adjustment tweaked in last night and I'm pleased with the outcome. I'll get some pics on the road tonight showing the true output.
When changing the headlights, I discovered an air leak in the airbox. One of the screws had stripped out and was keeping the lid from closing all the way. I snagged a bolt and nut from work to temporarily fix it. I'll run it like this until I get a new airbox.
I also decided to clean the throttle body and mass airflow sensor since I had been getting a bit of a rough idle. The maf wasn't bad at all, but the TB was pretty bad on the backside. Probably from the pcv return before I installed the catch can. I didn't get any before pics, but here it is all clean. It's not perfect, but not bad for my first go at it.
I picked up a used Range AFM Disabler around the same time as the LEDs, so that is in as well. So far I think it's well worth what I paid since I don't think I'll have the funds for an actual tune for quite some time.
The body lift is still sitting in the garage. I haven't really had the time to mess with it, so it will probably have to wait until spring rolls around.
