official aSSmeister build
it will work, they work in 4l60 and 4l65 trans
and ebay is your best bet greg for your handles.
Cool thanks! I'll try and PM him today. Chris is right, the only listing that had the part number for the handle pair couldn't find them either.
I did find one other listing, but it's all 4 handles for $200..someone suggested buying them since handles are scarce now. They think the rear handles will work as front handles for someone else if you switch the internals.. Which, without looking at my current ones, idk if it's possible yet
Found my handle issue.. Piece that connects the rod to the handle spring snapped -_-
Got my other handles in
And fixed three leds that weren't working. Driver door panel, passenger puddle lamp, and passenger reverse. Annd the vette servo and shift kit are on their way
Cleaned up preds today
Steel wool to the backs
Before little polish
After
Then finafuckinly washed the truck
Still decent shine
Need to do something with the backs.. Either paint black or just plastidip.
Three are like this
One is a lot cleaner lol
The only loose stuff is on the inside of the spokes. I'll just cut the flakes down with a razor blade and hope they don't keep lifting up. I hate plastidip but it'd make sense here
Fuck it, hit it with a wire wheel on the end of a drill then the plastidip should stop it from getting worse.
Ya I want it to stay there. It's only going on the back barrel of the wheels to cover up that bad pitting. Instead of doing matte black paint and flat clearcoat then worry about it sticking.. Way better off just fgt plastidiping it.
That wire wheel or sandpaper would do the trick out back there
I may be the odd man out here, but I'd run stockers before those Preds. I'm just not a fan of aftermarket wheels on SS trucks. Maybe I'll change my mind when they're on.
I'm iffy too.. But for a cheap make over might as well. I like that they're chrome and an inch wider.
Example of when done, but not as low lol
