Imo. Not overly flashy but clean as f0k.
I'd want an rcsb set up almost exactly like this, maybe with an inch or two higher.
I keep debating a 1.5" body lift on it, but then I'd have to modify an hd hitch a little bit, get rear fender liners, and add e-fans so you couldn't tell, kinda like what Kelly did on his truck. amps would be a nice christmas present too...
What's your exhaust set up? I want a bigger dump
I have 3.5" dmax tail pipe cut and re-positioned, with a 6"x30" piece of stack and 4" adaptor hanging down. It's not where i'd like it because of when I relocated the shock to the back of the axle, but my tip is almost too long to use as a center dump either, so idk what I'll do. It looks okay the way it is now, just moves around and hits the shock is the only problem
