Yeah I'm gonna crawl under there and check it out when I'm replacing everything else I do have a vacuum line that is not unusually long lol probably coming from the evap canister. Probably got pulled out while I was running the rear lineEvap code could be the canister at the back of the tank.
pretty good deals.
i wonder if the pads dust a lot.
Thanks fuso taking to to a local guy with a tech2 to have the abs bled and if that doesn't solve the issue than I'll look into the booster and master cylinderI would check your booster first, they can do funky things when they go bad ,like making the pedal super stiff, making it like semi truck strong brakes or having no power assist and allowing to go to the floor. It's not bad to change out either.
i would guess booster. if the master was bad, you wouldnt get pedal when the truck is off
im just saying, if you sit there with the truck running, and you get a good hard pedal, then the master is fine. once you have the motor running and its pulling vacuum on the booster is when its fucking up.
