Good news and bad news. Mostly bad news......
Picked it up and one issue they found is when you turn the key to crank the motor, there's about a 1 to 2 second delay before it actually cranks. Never had that problem before. Could be something simple as the solenoid on the starter.
Then more trouble...driving it I noticed my oil pressure wasn't reading. Pulled over stopped and shut it down. Went to access my oil pressure via my CTS. Start and shut down a few times but my CTS started acting up and would go blank. Then my cluster went all ape shit. None of the gauges worked except the tach and speedo. Went to drive it back to Accelerated and it wouldn't shift past second gear. The cluster has something fucked up with it. The guys will diagnose everything and go from there. Probably time for a new cluster.
Another thing, the exhaust is hitting the cab and is also resting on the transmission crossmember. But with it hitting the cab, it's got a god damn rattling/clattering noise. It's bad. It goes away when you're driving it when the motor torques the exhaust to clear. SOLUTION...build a home made body lift. I think using hockey pucks will give me the correct clearance and will allow clearance in other areas especially with the hood hitting the charge pipe.
Good news, got to drive it for the first time for 5, maybe almost 6 weeks. Runs good! A little doggy at first but holy balls when that s475 lights!! Damn its a screaming rocket!! They said if I hooked up the Co pilot, it would help out a lot and lock up the torque convertor quicker. Help with in town driving.
