Soooooooo clean
Sent from your sister's house
Probably hangars. But I've never messed with them on an nnbs. Someone will chime in with a better answer than me lolOK, so I've dug through everywhere I can think of and have come up dry. My truck is currently dropped 2/3 and I'd like to get another ~1" out of the back. Is there any way at all to do this without doing a flip or sacrificing the ride or functionality of the rear suspension? I have 2" drop shackles and the block removed.
He'd have to go 3" in the front to be fairly even.Was gonna say the same as noe but I think a flip kit set at 5" would be a better choice imo.
Flip kit is 7" so you would have to add hangars or something different
Sent from my SM-N910P using Tapatalk
Well here's the thing, if I do a flip, I'm pretty sure I'll go on and go 4/6 since its actually cheaper than doing 3/5. I don't want to hack off the factory hanger to gain just an inch either. And thanks for the input so far.I guess I was thinking the flip with adjustable hangers then. I saw an adjustable rear kit for nnbs that had 5" rear as an option. So I guess if you are doing hangers either way then a flip isn't really necessary since you don't wanna be that low. Lol
Sadly enough, I think that is the only other option at this point. I could pull the overload and sacrifice towing capacity or pull the bottom leaf and possibly sacrifice ride quality.remove a leaf?
:cheeky:
