Completely understand man :shake:
I'm trying to get my shit together before the Shreveport meet!
Niceeee, definitely ready for the meet. I need to get a thing or two down also :secret:
You want the 6-7'' Belltech's... Pm Tony or Kris from Suspension Source and she'll give you part number.
But those would be front** coil springs and Yea don't use mcgaughys shocks or extenders.
Curious, running a 7 inch on my setup and running belltech SP, should I not be running shock extenders?
Lolol, yea, I didn't even want the hassle
Clint, ask jared about Belltech SP shocks, DNFW.
I believe it, but with it welded now it wont be much of a hassle. Cursing once a month because a damn pothole or dip is rough enough to pop a bolt. Just needs to make it for a year so I can save up.
Were you breaking grade 8 bolts?
I have wondered this also, but I was just told that pretty much shock extenders blow which many have emphasized this a couple times even on here in the past couple posts. Ride is not rough or anything, ride is good actually...just if I take a couple bumps that are bad, and we all know in louisiana you can only avoid so much, eventually it just either shears the head off the bolt or shears the bolt shortly above the head.
My 4/7 rides great without the extenders
