I never intended for my truck to be an exact copy of Kyle's truck. I've just done little things so far to set us apart but I'm about to lift mine and throw on some 20x12's along with some other changes and it sounds like he is looking at some 22's.
I don't really care for lighting under the truck/behind the grille.I say you want accent lighting do white in the wheel wells behind the grille and on the rear shining on dem tips. Is under lighting kinda rice but it seems you show your truck alot so its perfect
meh, I would probably rock flares if I found some cheap but they aren't that important to me.You need CM'd OEM flares, even though its like Kyle. It just looks so much beefier!
Way to be a homie lol.Branson has some lol
Also got a quote from Kristy over on gmfs for a 4" rcx with steering stabilizer and tr sleeves for $995 shipped :notbad:
Exactly. That's why I'm getting the 4". I would rather have a little lean with the 4" block than texmex rake with the 6" block.Just get the 6" rcx and run it decranked. The only difference between the two is the block
I thought it was basically 4" if decranked or 6" if cranked. :think:Lowest this kit can be ran is like 5-5.1". And would look perfect with 4" block on your truck Aaron.
