So If the mirrors don't arrive then.......mirrors and tips will be here tomorrow
Well I guess I was hopelessly wishing I could just pull the sensor up through the dash but about 30-45 minutes later I realized that wasn't the case...
but I got it done lol. Atleast now I know what it takes to get the dash pad off if I ever decide to do an interior swap.
....you'd get just the tip.
for anyone trying to get to the sensor through the dash and keeps cutting their hands up on the razor blades GM has in the dash, removing the top cover is extremely easy. Pop the A pillars cover off and unplug the tweeters, pop the two panels off on both sides of the dash, pull the bezel, pull the passenger side air vents, pull the pull handle (2 push tabs inside the vent openings), twist the light sensor out, remove the 2 Phillips head screws on both sides of the dash (4 total), remove the 2 Phillips head screws inside the vent openings, remove the 7 or 8 7mm bolts across the top of the dash, pull up and out on the passenger side of the dash (has pop tabs), lift the dash cover off. Takes about 10-15 minutes to get off and saves a few pints of blood and couple layers of skin. You can get to everything on the top of the dash, including the sensor, A LOT easier!!!!!!
"bend some pipe" is pretty elaborate lol explain what you're wanting them do? Replace tailpipes with new bent ones or bend these?I'm not crazy about it. plus, muffler shop wanted 170 just to bend some pipe and throw the tips on. FTS
Well that's why it costs more dummy. They have to bend it a lot for what you're asking. I think 170 is a very fair priceI currently have the exhaust dumped at the muffler s they would need to run new pipes out the back
Just go up there with 140 in cash and be like this is all I got, can we work something outThat's without the labor of them bending and welding the pipe though lol.
I think 170 is a little high. 100-140 seems around what it should be imo.
Bolt on? FtsNo I mean I can get a bolt on system for around 300. One that I could put on.
Bolt on? Fts
