I can't stand cleaning these every other day when it rains for a week or two on and off and once winter comes it gets shitty. Also, I will be in Nebraska for a week and a half at the end of the month then Oklahoma for a week in December. Ol' girl is going to get some miles stacked this winter. dnw these rims to get the winter abuse because once it gets less than 50* outside, I will not clean them as much as I do now.
Plan on gears if you're lifting on 35's too
have 3.73's now. What would I need to change to?
4.56s put you back into the stock feeling range. 4.56/35s feel about like 3.73/285s. Me personally, I'd do 4.88/35s so the truck has a little more ass to get moving. And its only a couple extra hundred rpms on the highway
Sent from Tapatwat
I'm running about 2100 rpm at 65 mph iirc. I'll check again today
edit*
I remember seeing a post on ig from a guy who was running 37's and 4.88's and it ripped his tcase from the trans and fucked up his whole drivetrain
:scared:
Lol that's all in driving style. Half ton drivetrain isn't meant to turn 37+ tires no matter the gear. It can be done, sure, but it won't hold up forever and if you're hard on it it's gonna break. You'll be fine on 35s
4.88/35s will actually be easier on the truck than 4.56/35s because of mechanical advantage. 3.73/35s is like trying to get a stuck bolt off with a 6" ratchet, 4.88/35s is like using a breaker bar on an already loose bolt.
Sent from Tapatwat
