Mine's 06 with drums already but I'm doing those ^ powerstop rotors with ceramic pads and ceramic shoes out back with stainless lines. Mine stops fine right now but with the 20s and 33s I could def use some more brake
How much all that shat run you?Sup twats
I did front powerstop calipers powdered red for an 05 silverado with rear drums (bigger front brakes) and drilled/slotted powerstop rotors up front.
For the rear I did 05 2wd Tahoe calipers (dual piston) with drilled/slotted powerstop rotors.
Used generic brake best ceramic pads at oreillys (damn good pads)
I also did stainless steel brake lines all around by Russell.
Brakes are bamf, stops way better than before
It's aboot time to do my front pads and rotors. I'm down like Bobby brown for some bamf rotors and calipers.
Hook it up with a link
Since you're gonna be running such huge fucking wheels and tires you need a real upgrade. Like Wilwoods or Baers. At least get the Baer +1 14 or 15" rotor kit
Bruh, he's talking about his silverado. There ain't no 05+ brake upgrades for powerstrokes lol
He was just talking about the new lift and 22x14s for the silvy in one of the other threads earlier tonight. Bruh.
Sup twats
Glad you chimed in..
Would those be the same front calipers as what I have now? Did you notice any brake dust with those pads? And any rust form on those rotors(pad surface and on the edges)? Also, would those same rear calipers bolt up to my truck? Sorry for the fuck bomb of questions.. didn't realize how little I know about brakes until today lolz.
No, 05-07c have larger rotors which require 17"+ wheels. Those along with the Tahoe dual piston rears and good lines are an awesome upgrade. That's my plan once I sell the 16s at some point.Glad you chimed in..
In the back, yeah. When you do the 05+ front upgrade, no.the suv calipers should fit in the stock 16" wheels iirc
Ever thought about lifting ur truck (6" RCX or whatever), running it @ 5", and running ur 20x10 Peds & 33" Toyos, and add 1.5"/2.5" spacers?
Would be BAMF stance, until you recouped some $$ for X12/X14s
Idk how you want to run X14's lifted though, that would be like 9" sticking out past the fender without flares on the front...
05 tahoe 2wd rear calipers, right?the suv calipers should fit in the stock 16" wheels iirc
So what's different about the front with this 05+ upgrade?In the back, yeah. When you do the 05+ front upgrade, no.
Idk. Just dreaming I guess. hell I might do 4/6 on 22s. I can never make up my mind.
