Yeah with the spacers, you're gonna have to trim a good bit to fit em with spacers. I had to trim the front bumper, front and rear inner fender, and needed do the norcal mod too but did a 1.5 bodylift instead
Yikes hopefully I only have to trim the plastic for the lower valence and not the the metal. Trimming is not big deal as long as its plastic. Now the norcal mod hmmmm idk about thatYeah with the spacers, you're gonna have to trim a good bit to fit em with spacers. I had to trim the front bumper, front and rear inner fender, and needed do the norcal mod too but did a 1.5 bodylift instead
Fuuuuu I hope it's not too bad maybe I'll have to go with 1.5 instead of 2 in spacersin before #boltonframeslicedmytirewhatdoIdonow
:cheeky:
I have a sawzall and a grinder need anything else?you will have to trim metal with the spacers. without you will be fine.
What's Jakes ecsb.. Level, ss 20s, 33 troll graps, x" spacer and 1.5bl or nawh?
Hmmm pretty much the same as huck tooyep he has the 1.5 spacers and the 1.5 bl, his truck and mine have almost the same specs
