So a couple weekends ago I took the truck to the strip for test and tune. Had tons of fun running the truck, but got a bit disheartened about how slow the truck is. I tried to keep telling myself how heavy it is being a crew cab, keeping times down. Here was the best run I got that day.
After going to the strip, I'm really starting to rethink the direction I was going. Honestly, the truck is fun to drive as is, so I don't really need anymore power. A tune would still be nice, but isn't really needed either.
I need to crawl under the truck and take some measurements, but I'm leaning more towards going 4/7 instead of the performance mods. My main concern is axle clearance in the rear since I'd like to avoid running a notch. With all of that said, this is what I'm looking at going with to get to 4/7
Front:
Really been tossing this one around in my head since I can't figure out exactly what I want to do. Here are the options.
(1) Belltech Drop Coils - I can get them for less than 200 and they are a fairly easy install for me. No turning radius loss and from what I've heard they don't ride bad either.
(2) Spindles - I don't know that I like this option too well. I know they retain ride quality and alignment, but the loss of turning radius really bothers me. I would also be clueless when it comes to the install.
(3) DJM Lower Control Arms - Haven't really heard much about these, but I was planning on getting new lowers anyways since I'm pretty sure those ball joints are shot. They are a little pricey, but kill two birds with one stone and would be a simple install.
Rear:
I'm trying to get the flip that's listed in the classifieds here, but if I can't get that I plan on going with the street edge flip kit.
Shocks:
My current shocks are for 2-4 rear drop. Can I run these with extenders or do I just need to get new ones?
Helpers:
These may not happen right away, but will probably be needed. Should I go with the mcg helpers? I believe they run about 400 for the set. These are floating around on craigslist.
http://lexington.craigslist.org/pts/5202003813.html If measurements are right, would these work? Since I work at a machine shop I could make all of the mounting brackets and such.
Anything I'm leaving out for the drop?
