Heavy tires still heavy
This, gears won't help the fact that those tires were heavy.
Gears actually would by increasing mechanical advantage, is part of the reason you regear when lifting :truestory:
You regear when lifting because of the larger tire diameter. Gears do nothing for weight, doesn't matter if your tire is 40lbs or 140lbs, if they're the same height the gearing will all be the same. Now the lighter tires will make a difference, but not because of the gears. Because of the parasitic loss of heavy fuckin tarz. :gnomesayin:
Yes the change in mechanical advantage helps, 4.10s would be stock gearing for my obs with 37s to make the speedo correct but 5.13 is as high as I would go for 37-38s. Same reason you regear for better acceleration or for offroading because it makes it easier to get the vehicle going thus felling like it has more power. Also :shake: for brining tech into ASP thread with me :troll:
:lolwut:So why again did you go from BAMF troka to where we are now? I apparently missed it.
:shake::mynga: had to make this thread less stupid :lol:
You won't do it I bet.
dont even list anything for him he has asked like 5 times, says hes gonna get and never does.
Your parents are.
if you aren't made of money, then either keep the truck as it is. or quit spending money on the stupid vaping bullshit
