05 CCSB slow build
Goes to mexi
Takes pic out of window of beautiful scenery
Can't even get sex pic of troka with beautiful scenery as backdrop
:mexiokay:
When you did the flip kit did you remove the bolt out of the driver side leaf spring in the front?
btw, no need to drop the hitch either when u wanna remove shackles....lower n raise the truck from the hitch so u can remove/install the bolt from above the frame...once bolt is in...u can bolt the shackle to the hanger and ur done.
so ive been buying parts here n there to make me a bracket to mount my air chuck and switch. will bolt angle iron to xmemer, some square tube, then angle iron to bolt up some diamond plate. Air chuck will be activated with a switch that will open and close the air valve. Ive seen too many air chucks leak...dnw it plumbed directly to the tank, hence the e-valve. All this will be hidden behind the lic plate which will flip up with simple hinges. Plate is done, just gotta start cutting some metal :pepper:
