05 CCSB slow build
It was a pain getting to the rack n pinion line....had to drop the rack. The line at the pump wouldn't budge and I stripped it....had to put vice grips on it. The HB didnt fit in the firewall hole so I had to make it bigger. Honestly it CAN be a pain but it can also be easy as fok. Worth it regardless.
If u have the 4wd steering then its way easier. I took the lines off a 2500 burban and its easy as fok. The lil fgt is was the pump line but came out easier than mine....do it!
fgts :nono:
did it fuck the paint up at all? or did it leave a mark so you can atleast tell what color car it was that did it
was silver/white car....no paint damage luckily...just pushed the bumper back into the fenderwell and pushed it down. Im going to try to fix it today....put a tie down strap from the bumper to a pole and tighten down on it...hopefully it pulls the bumper forward....then I can put a jack under it and push up.
