Static NNBS (GMT-900 07-13)
Some help in want to drop my truck 4/7 when I bought the truck came like this it looks level and I trying to find out that can I do to make 7 drop I looked if had a shackle but I thing they remove a leaf spring
Flip kit will get you 7 in rear
But I will be more lower because of the leaf spring remove? I don't know if I measure right the back tire to fender is 37in and the front measures 36 1/2
Sent from my SM-N920T using Tapatalk
Count your leaf springs, these trucks should have 3 total. Also, take a picture of the shackle and see if there is a block between the spring pack and the axle.
It has only 2
Is Mcgaughys 34070 kit a good kit? I will ask few friends is they want to trade my leaf spring for theirs
Helped my brother in law out today. Lowered their Yukon. It's a 2/4 drop using beltech struts up front and beltech springs in the rear. Also debadged it (needs demolded too, but we ran out of time).. Tires are 295/35/24. Had to do a good amount of trimming on the liner in front of the rear wheel. Other than that it turned out good!
Oh my god that's perfect
It's relatively tight above the tires like it sits.
It rubs a little on the front liners if the wheels are turned in reverse.
The rear rubbed constantly so I trimmed a good bit of the plastic liner back there.
Could probably go another inch no big deal, just have to trim a little more. The front can be heated up and pushed out of the way I'm sure, and be just fine. I told him to try that and see if it fixes the rub
