whats a spare? LOL JK JK. mine were trimmed because I ran on 17s a while. other truck I always figured just swap a wheel. from back to front if necessary
If you do get the 17" spindles then either plan on finding a 18" or bigger spare wheel or you need to grind down both lbj studs if you have a flat to run your 17" spare or you can pull a rear wheel off to put on the front then put the spare on the rear. 16" spindle you wont have to do that.
I dont know about yall but I have the 16+ McG spindles and dont like them... I lost a good bit of turning radius, like to the point drive-thrus scare me sometimes because I have to go forward, back up and then go again if there really sharp. But its only when turning left, I have all of stock if not more turning right. I plan to swap out to a pair of our Belltech spindles before much longer. After that I will sell my set of McG that I painted black before install so they wouldnt rust or anything.
As far as parts for you drop Jared I would go this route give/take what you decide.
2/4 Drop
Front - 2"-3" Belltech Pro Coils set at 2" Drop
Back - 6" Belltech Flipkit w/ 2" Lift Shackles and AirLift Helpers
With Belltech Street Performance Shocks all around.
I mean reason I say this setup for you is because when you decide to go 3/6 all you would have to do is remove front spacer and make the Pro Coils 3" since they are adjustable and then remove your rear lift shackle and you have 3/6. Its easy, will ride great and wont cost you any more money in the long run besides a notch.
Some pics of 3/6 I dont really have any of a 2/4 that I know of, these pics just gives you a good comparison of a really low static vs. a great everyday comfertable ride height.
Colyn.
Colyn.
