RCSB Derpamax Build
why do you have ao many lights on with the dash corny.
ABS, cel,
i assume you dont have it tuned yet since you blocked the EGR?
ABS I think my driver front sensor is bad. But the truck brake fine and ABS functions like it should when I stab the brakes
CEL is because I dont have a new airbag module yet. Truck is tuned though and I shut the DTCs for the egr and intake heater grid off.
I'll do 4wd launches when I get tie rod sleeves
ABS I think my driver front sensor is bad. But the truck brake fine and ABS functions like module yet.
Last time I had an abs light on it was because my wheel bearing was coming apart and it ate up the end of the sensor..truck drove fine until we were getting ready to leave town for turkey drag back in November
Might be something for you to check into :shrug: iirc a new hub with abs sensor was around $130
imfo ging. dfw ken doll cawk pics on le phern.everytime i buy a ken doll i pull down his pants and theres nothing there :okay: do not need zoom for cornhells monstrosity tho :gnomesayin:
Put my 2" spacers on out back. Helped a lot
Also have the fogs but worked today so didnt have time to put them on.
Is it just me or does the bumper have alittle gap on driver side amd no gap on passenger? Might be picture angle....
Yeah the bumper wasnt perfect. I ran out of washers and had the wrong bolts for the side brackets. The ones I had were too small and made for a lot of play when I went to adjust it.
I got the right bolts and put the fogs in today. Also washed it up for the first time.
Front track width is 1.50 wider out front on gmt 800 trucks
