Looking for turn signals, help me out brodudes
I have regular oem type tyc and they are great, had a problem for a few months with fogging and bulb seating but that is just because I'm special. Im auctually kinda glad this is a slow moving upgrade. Because there is more involved with this than just parking lights. I'd I got the clears I would have to get at least two sets of amber or switchback LEDs and the proper relay to accommodate them. That turns this upgrade into like a $100 mod :nono:
Cornell had a how to on it. You need to break one of the contact pins on the flasher, I'll see if I can find it.
**edit**
Found it.
Modifying the stock relay:
Remove 2 7mm screws from bottom of panel.
I "rock" module back and forth to get it out or it can be a pain
Apart: I use the paint can opener in the picture to open the module up... its easier than a screwdriver.
Figured those pictures would help people. I use a tweezers to knick the little leg off.
Look at the last pic the bottom left of the flasher board there is a small black square with 8 terminals coming out of it. You need to clip the one on the top, second from the left.
That only on the 99-02 isn't it? If not I missed it for the 03 and up
OMG OMG OMG OMG They're BACK.
I may grab another set. Mine have a few stone chips and I wouldn't mind a spare set just in case they go AWOL again.
