Which toyos? Dfw something under 50lbs per tire
Sent from a dingleberry
Raceline renegades? That'll look good, wanted those on my last truck. The main thing is not going to an E load range, that's where all the weight is. These terras I have now are still Es and are 19lbs lighter lolP285/70r17 going on new 17x9 renegades which are also like 10 lbs lighter than SSS 20's
live from the gutter trash.
:secretshake: Gotta decide how low I'm going firstJust let me know the size you you're thinking about, you know you'll get a deal. :cheeky:
17s? :scared:
You think I could drop it a good bit on these? I think I could get it pretty damn low with some stock keys and shackles on these. Especially cuz of how much I'm trimmed lolI will say the new tires are a good bit bigger than I thought they would be, almost too big.
ALMOST :rofl:
And the ride too. E load range is mostly 10 ply. These P metric are 4 ply hoping for nice and cushy lol. I don't even think when I worked with my truck I ever needed the e load range tires. These p metrics are still rated for 2,000+ pounds which is more than enough for anything if put in my bed
IMO. I need load range Es cuz I tow alot and some pretty decent weight sometimes but I'll just have to be more careful and not tow as much in the future. Although, it had P load on it when I first bought it and towed my boss' heavy ass car trailer with a 68 Camaro on it without any issue. I'll probably go load range D next so I can tow without worry if need be
Thinking I might try to find some 275/55s on CL for like $100 and see how low I can go first285/55? probably remove the body lift is all. Width is more of an issue than the height, you could do a 2/4 with 275/55 with minimal rubbing. All depends on how low you're looking to go, 2/4 with 265/50 is ideal but if you want to go lower than that I'd recommend a 275/45.
When you take off that bodylift let me know...I want it JUST in case.I still plan on getting some even lighter tires and going down. Just gotta scrounge up the few parts and find the time
Not really. Honestly I'll probably start with decranking these keys all the way and see where that gets me. Then trade someone for stock keys or just buy some and get some shackles/pull the block. Don't really wanna do much more than that. I bet I'll need to get some angle shims for the rear too
SD truck spring. Got mine from there. Beefy and the correct length.I've got 2" shackles if you want them. Just sitting in storage right now. Still need to put the shims back in mine, have to source some longer u-bolts first.
