Was very easyHow bad was it to change the wheel? I need a new one for the GMC.
	Did it come with a wiring diagram of the switch?Any idea if I can swap to a smaller switch for this cut out. The factory switch is huge and ugly![]()
Wanting something smaller like this![]()
I was wondering if since its working a motor (the cut out) that if a on/off switch, when in the on position, will it continuously try and open and burn up the cut out motor?Black=ground
White=acc
Yellow=12v
Any three prong switch will work.
I gotcha. You said any 3 prong. The switch it comes with has 4 ports...Yes, you need a momentary switch, not just a toggle. A toggle will kill the motor because it provides constant power. Think of it like w window switch, when you let off it cuts the power and the window stops. Same with the cutout.
	I thought it was going to be horrible. But when your driving you don't even notice itdoesnt look too bad there.
yea i want one of those mother fuckers, mines getting worn spots and want to upgrade to wood one
