Brettrunner 2:Cruise Harder
I just put the methods and 33" toyo m/t's on my truck, it rubbed... This is the combo your running? Some people don't rub but it's all in the offset/backspacing and other little things that change per vehicle. I ended up doing the NORCAL Mod on the rear of the front fenders and then trimmed the fender liner in the front of the fenders. Also I need to replace my struts as I think they are a little saggy making th front sit a bit lower than it should.
[/url]
Is that a 4WD ?
if so yeah a 4WD truck with a 2wd offset rim will rub.
Thinking about this muffler,
http://www.amazon.com/Magnaflow-141...id=1368005532&sr=8-1&keywords=14151+magnaflow
or
http://www.amazon.com/Magnaflow-141...id=1368005601&sr=1-1&keywords=14161+magnaflow
yes 4wd. Looking at going a little more high with the RCX 4".
I like what you're doing with yours (subscribed). Should have held out for a 6.2. Looking at probably selling this truck and moving into something newer... You think I could pull 16k out of this one, 72k on the odometer LTZ package?
Absolutly i would have paid 15 or 16 for it.
Yeah on average people are claiming high 13's with just simple mods.
The methods weigh less than the OEM 20's but the tires are about 10 lbs each more than the goodyears so ill be pretty much the same there, and I think im going with 32.7's so its only .9 inches bigger than stocks so performance wont be affected.
Ordered an AeroTurbine today. Heard nothing but great things about them. Going to keep the stock resi in though because they are loud.
