Alecks' hopes and dreams thread.
Spare is 31" trails are 33" I'd rather get towed then risk running a 2" tire difference.
Haven't really updated anything in awhile but I have 2" drop shackles I'm putting on soon (set to 1") and then sometime after Christmas, maybe for my birthday I'll be doing full exhaust and tune
Any tips for installing these shackles?
Also, my sub is entirely too shitty to keep using, good under-the-seat (extended cab) 10" sub setup?
Edit: Also finally getting these scratches out rather shortly
Run 2 8s instead of one 10. You will enjoy it more.
Sent from my Stealth Lookin iPhone using Tapaturd
Remove shackle bolts, remove shackle, install new shackle, install new bolts.
:cheeky:
Honestly just lube everything a day or two before going to install them. I know on mine, my one bolt has literally welded itself to the rubber bushing, so it would be a pain to do mine.
I have had two pro-boxes with kickers and ported and love them. That's what I'm running in the dmax right meow. Blow 2 12s out of the water... If they're in a shitty encloser that is..
Think so? It'd probably fit better in an ext cab too.
you'll still have trouble fitting them in a nnbs, space sucks. sa8 or similar size wont fit correctly without being front firing and that wont sound as great as a df setup. for sq, sealed > ported. but if you want loud, high school parkinglot bass, then stick with ported
I don't want obnoxious loud, just enough to get noticed, but keeping it controlled if you get what I'm saying lol
