PAC1518Sorry if I missed, but what springs did you go with?
Well the 99-06 5.3 is rated at 285hp at the crank and the nnbs 5.3 is rated at 315hp so +30hp from heads and intake on a stock motor, obviously quite a bit more once you Factor in the cam and bump in compression from the milled heads.I'm interested that this little engine makes such good power.
I was contemplating a 243 head swap a while back for my 5.3, because those heads and intake are what the nnbs engine come with factory. Would be interesting to see the gain with just the 243 head swap and nnbs intake over a stock older 5.3/4.8?
Sent from my One X using Tapatalk
