hmm ok, this truck could definitely use better shocks, BEL-991SP set at 3/5 will the stock 255/70r17's work?
More suspension info: that silver reg cab has installed coilovers in the front. I do not have a part number for the rear shocks yet.
From Vi-king: c120t shocks
From Vi-king: 12dp600 springs
From Jack-it: 91-3712 coilover mount
If you are doing just 2" front drop you should be able to avoid the camber bushings. I would suggest using the strut over the spring though
May i ask why you recommend the strut over the spring?
