03-05 used that style cluster. As far as gaining those features, I'm unsure. You may need to have the bcm flashed.
That looks like mine, only I didn't replace mine, I had the steppers replaced, trans temp added, and esky overlay and rings added. Trans temp worked out of the box no bcm flashing needed, and I kept my mileage minus the few I put on the truck while the cluster was out. Think it was around $250-300 a few years back.So I have decided now is the time more than anything to do an Escalade cluster swap. From what I've read its a direct plug and play. My question is as of now my cluster does not display engine oil life or mpg average. Just engine hours, trip counter, and odometer reading. If I swap to an escalade cluster will I gain those features? I am looking for one like the picture below, not to sure what model its out of I believe it is an 05 can anybody help with what model? I know in these trucks the milage is stored within the cluster itself so I will need to have it reprogrammed and also where should I look for one? I don't like rock autos price tag and gmpartsdirect no longer sells it. Since my truck is in miles and I live in Canada I am trying to avoid having to switch over to a km/h cluster.
And 2 mondays ago or so I got the truck side piped. Single 3" in dual 2.5" out flowmaster super 10 to 2 3.5" tips. Im diggin the sound.
I think you're right, if it's even possible03-05 used that style cluster. As far as gaining those features, I'm unsure. You may need to have the bcm flashed.
What was the process of sanding the bumper cap and did you paint it with rattle can? Clean build by the way my truck is the same color but extended cab
