what was your process for the piece of glass molded to the floor? Watching you do this makes me want to actually do something again haha
Sure you can. I almost did and aero port because it would have taken half the time but the port velocity would have been 115 f/s and with a 4" square port its 90 f/s so I shouldn't get any port noise with it cranked up.
With a single 8 it would have been pretty easy to build.
If you're doing an 8" you won't need as big of a port or at all if you're going sealed.
If your port velocity is over 100f/s then you will get port noise when you crank it up louder...it's bad. And if your port is really shitty you'll get port compression and it isn't good either.
Should have installed it anyway and wrote "Boyett Bros Kustomzzzz" on it with a sharpie :imo:
