Question about bagging
What the hell does the bed floor have to do with the air tank? The bedfloor and frame stay the same regardless of bd.
What I was getting at was the only time the tank was close to the ground was full Cali, no bed. Bodied and with the bed on, my truck can't go that Cali without the bed being smashed. So there's more gap because the bed stops it from going lower when it's Cali.
Another question.. for the vu4 and a accuair switchspeed controller... do you have to get their 200psi pressure switch to run the adjusted pressure levels or could I run the one that comes with the Viair 480c compressors...
Sent from my DROID RAZR M using Tapatalk 2
Talked to the place I bought it from said it would but he didn't sound to sure on the phone. So any input would be great
Im not too familiar with the switchspeed, does it come with an ECU like the e-level does? I had to use the accuair sensor when I installed my e level ecu
Ya it comes with an ecu but its not the same as the elevel ecu. You can go through a azproperformance.com and send your controller and ecu in and only pay $775 to upgrade to the elevel w/ the new ecu. That's what the guys said on the phone. You can pay $1350 or so and they will send you a loaner ecu and controller so you don't have to have your truck down and they will refund you once they receive the old ecu and controller. They also send you a shipping tag and everything.
To have different tank pressure settings, yes, you need accuair's pressure switch.
So do tanks lose pressure easily running the bags?
I don't understand the question.
the tank pressure will drop everytime you fill the bags, but you aren't losing air because you're sending it to the bag. if you're losing air, then there is a leak.
Ya just gonna have to wait to finish my truck and play with it to actually see what its like. Just trying to get an idea I guess... kinda a dumb question. I was wondering how much pressure you lose when you hit a switch... just like tapping the switch
