James Pate New member Mar 27, 2012 3,691 112 0 34 Margate, Fl Apr 8, 2014 #1 Ok So I have a power steering leak and was wondering if any of you knew the simplist way to fix it, should I just get a new gearbox, replace a seal, or?3 Here is a pic
B bgray Stylish Canadian Mar 17, 2012 3,052 96 0 38 Onterrible, Canada Apr 8, 2014 #2 If you can find a rebuilder, they cna rebuild it. Or get a new one from GM. Thats what we do at the shop
Big Tex slowly but surely Jun 25, 2012 7,951 207 0 Dallas, TX Apr 8, 2014 #3 mine is leaking, same place. actually has been for over 4 m onths but I just add fluid when it's low. eventually I'll replace the gearbox :bishplz:
James Pate New member Mar 27, 2012 3,691 112 0 34 Margate, Fl Apr 8, 2014 #4 Thinking about replacing it with one from PSC when I do the sas and also doing the hydro assist
Cleanoh4 New member Aug 27, 2013 4,346 185 0 40 NJ Apr 9, 2014 #5 I may be wrong but I think your pitman arm is a little loose
coldburn New member Apr 11, 2014 37 1 0 34 Apr 21, 2014 #6 See if its just loose fitting or see this vid: Fix Power Steering Leaks Chevrolet Silverado 1500 (2007-2013) - 2008 Chevrolet Silverado 1500 LT 5.3L V8 Extended Cab Pickup (4 Door)
