What's up guys. Decided to hold off on the suspension for a while. I like how it looks just with the shackles and stock rear block removed. It's a clean simple look that doesn't sacrifice the ride comfort. Decided to pull the trigger on full bolt ons and tune instead. Just trying to get all the parts needed before I install it the first week of October before the BlackBear tune out in Fort Worth. I want to have everything needed minus the cam, cam kit (cam, springs, pushrods, lifters, dod delete, afm bypass, timing chain and stall converter so please don't recommend me to do any of these add ons yet. They will be done early to mid of next year.
Right now I have Magnaflow exhaust, Lingenfelter 174* thermostat, S&B cold air intake, Taylor high heat spark plug wires, iridium spark plugs, Texas speed 1 7/8" stainless steel longtubes headers (wondering if I should apply a heat coating to the headers or not necessary?) & 3" off road y pipe, underdrive pulley, and a RX catch can.
I was wondering if you guys would recommend any other modifications along with these? I know throttle body spacer doesn't do anything but I was thinking about buying one anyway (just for throttle response) or if porting and polishing my stock throttle body would be a better bet? Also should I pull the trigger on intake manifold and gears now or can those wait?
Any input will be appreciated.
Thanks, TJ
