LBZ Derpamax Build
Well I found a good deal on an ATS diff cover and picked it up earlier this week, went to go buy some gear oil this Saturday and found out my entire city was pretty much out of 75w90 fluid... went to 9 different stores who supposedly had stock and only at the last one did they have 6 quarts.
:rage:
After getting fucked around all morning hunting this down I got the cover installed, pretty sure previous owner never changed the oil but drain plug looked good no metal shavings. Going to get a pic tomorrow of the cover but it looks decent and hopefully will help when towing the skidsteer on long trips.
Where'd you get those led cubes for the reverse lights? And how'd you wire them up?
:nice:
Kinda weird how all those stores didn't have that oil though
I was shocked I thought 75w90 was common but all they had was 75w140
Online.
And he used wires.
:cheeky:
I bet they are even mounted with bolts, srs tho trucks looking good
You would be correct Haha these were from Amazon I originally bought them to put on the skidsteer but decided to try them on the truck and I think it was a good choice. Here's a picture of how I mounted them, just drilled a hole in the spring perch, tapped wires into reverse lights.
Had some free time today so I decided to start working on the exhaust. I was running the standard mbrp 4" turbo back exhaust with a muffler and 3" downpipe. Never liked the way it hung down so low and kicked out to the side so I dumped it behind the axle.
Makes the 5" tip look pretty small so I'm thinking about getting a 7 or 8" tip about 15" long, should tie it all in nicely. Also went down to America and picked up my qtp cutout last weekend just have to find a place local to weld it in.
After doing the exhaust I went and started to put in some led footwell lights. No pics yet as I am finishing them tomorrow and may try and run some to the back seats as well.
