Jared, I'm still working on that feedback, once I get my bed on and my hitch off ill be able to tell what it actually rides like, right now with the bed off its just bouncy as all hell
Hopefully I can get some help tomorrow for the bed, I cut the back of the metal piece that goes in the notch like khaos said, and took the hitch off, much better now, once the bed is on ill look at the front drivers side again, something sounds like its hitting up there so ill check it out
Just watch where you cut that piece off. Idk if you have rear drums or discs. I have rear discs and on both sides the metal brake lines are directly under where you cut. You had to see them if they are there. I just bent mine out of the way of the notch if I ever bottom out that hard.
