Fog Lights on NNBS LS
SilveradoCowboy93
Apr 22, 2013
67
36
31
Beaumont TX
Ok so I have the steel front fender caps and no fog Lights or switch, I was reading up that I could just get the wiring harness for the lights and the new switch with the fog light option on them, will that be all I need once I buy the caps w/fog light hole in them? And the plastic caps should bolt up direct like the steel ones I have? I know there used to be a package you could get for this kit but heard they don't sell it anymore , suggestions?
I got one of the last Factory red end cap fog light kits that GM had left around. Not sure about aftermarket but with the harness button and end caps it was all plug-and-play very easy.
FFB device
Steel fender caps. They don't make steel. You mean chrome?
But yes the plastic caps is same design. It will interchange. But they're not "steel". You just have chrome plated plastic.
Reactions: BigBoi
FFB device
Does this look like the correct wiring harness for the fogs? Almost seems like it isn't long enough but it may be?
