Just a few questions guys. Ive been through enough setups with my tahoe but this is my first with leaf springs on a nbs.
My set up is DJM arms and drop keys in front, moog uppers with offset bearings, flip kit in rear. Supposed to be a safe 4/6. Im tucking tire all the way around, but im on 31" tires
Right now im 16 1/8" hub to fender on both fronts, 14 3/8" drivers rear and 15 3/8" on pass rear. so im over an inch and a half low in the drivers rear and about half an inch on pass rear.
So either way im low in the rear. I dont want to do a full inch in the rear on the pass side since i will be higher than the front. I could probably live with the .5" lower.
Drivers rear should i do a shackle to bring it up an inch? This will bring my pass front down, so i will have to readjust and get another alignment im guessing? I could live with that i suppose.
I dont think I can go any lower in the front than where im at. Im about 16" hub to fender. is this normal for a 4" front drop on a v8 torsion bar? I could maybe go down 1/4" in front to level it out more, but what do you think? tie rods are still pretty decent i feel.
What do you guys think I should do? I could run spindles and put my stock keys back in when i get wheels, but thats not going to help my CV and idk if that will help my top bj angle?
It aligned perfect, but its pretty much at the end of the adjustment. These are moog arms with offset bushings to gain more adjustment.
hard to see with the lighting, but its definatly low in the rear
pretty bad angles already (I think, especially since I will be doing 4x4 launches. even with the offset bushings, im still almost maxed)
