well get on it man. what i did with mine (i dont have any pics but ill get you some if needed) i built two plates for the mounts and drilled the holes out in each plate to put bolts through. then i put the bolts in the brackets and set it up to where i wanted and tacked it in place just to hold it and then popped out the bolts and drilled through the frame and put bolts in that. if you dont have a welder just mark where the brackets go with a paint pen and then drill the brackets and then bolt the tank up. i put mine where my spare tire went. if i was keeping the truck i would just cut that all out and build a section in the back just for the tank. my compressor is mounted inside my frame rail to keep it from getting muddy/wet
