Changing my stance up. Help with wheel dimensions please.
Oktain
Canuck Admin
Feb 9, 2012
4,982
232
34
Sudbury, ON
Help me. I've been searching and busting my brain on this because I hate posting noob questions... but I know lots aboot headlights, not this lol.
Plans: some 20's, about .5" of poke past the flares, tires will be stock OD, most likely Cooper Zeon's per J_Corr's recommendation.
I will be cranking the front enough to avoid rub under normal driving conditions. If I rub the odd time for the few times I'm offroad :idgaf:
Yes I'll have a little Cali lol.
Just help me out with the stock offset measurements on the NBS wheels, as compared to a 20x9 or 20x10 with around .5" of poke. I think I'm currently running a +12mm on my current summers, and they're 8.5" but that was long ago enough to the point where I can't remember what it was exactly. Just going off AR's website here.
if you want some AT's look into goodyear duratracs, kinda meaty and a lot of sipeing for traction. tires i wanted but were sold out when i bought my bfg ko's.
Duratracs are a possibility. But they're a pretty soft compound. Was hoping for something harder.
That STT is a good looking tire too. Might go that route.
I'm open to x10's too, was my original plan.
too much offset. That's 2" more than where I'm at currently. Looking for .5". Don't forget I'm not lifting much. DNW GoKart stance.
Edit: Looks like Method's offsets won't put me where I wanna be. Unless I wanna just continue running flush with the flares like I currently am, then I could run a x9 with +18 offset. Would give me stock clearance between inside of tire and frame. Hmmmm.
What do you guys think of the Mesh?
I could run these too. With the 10mm offset they'd poke ever so slightly compared to what I have in a x9.
I want to do x10. But that immediately rules out Methods.
And those HAVOCs, and Weld Cheyennes are one of my favourite wheels.
Was hoping to avoid a spacer...
Decided that a x9 with 0 offset would be perfect amount of poke... about .7" of poke.
Using my current wheels as a guide since they're flush with the flares.
