Things you will need:
- Suede (or material of your choice)
- Scissors
- Xacto knife or a straight razor (either is fine, but I prefered the razor.) MAKE SHURE TO HAVE SPARE BLADES
- Glue
- Ratchet with extender and 7mm socket
- Sharpie
- Plastic knife (or something dull to tuck fabric)
- Painters tape
- Something to mark your patterns on (I used wraping paper)
- Something to keep the area clean (I used cardboard)
Some of the supplies.
The suede.
Patterns I traced.
Cut the patterns out, MAKE SURE TO LEAVE EXTRA MATERIAL!
Take everything off of the panel.
Even the this.
Lay something down to keep everything clean.
Tape up the panel.
Spray the glue.
Wait for the glue to tack up, then lay the fabric down and start smoothing it with your hands.
Now start tucking the material.
Remove the tape to finish tucking.
Make relief cuts and roll the material.
After everything is tucked, start cutting the extra material.
This is what the panel should look like.
