05 sierra slow build
Not that I know of. Find the two wires that run to the reverse bulb. Remove the loom over wire. on my silvy tail harness it was a green wire and black wire. 90% of the time the black wire is the ground, so I spliced into the green wire. I only spliced the wire on the driver side reverse light. To hook up both cubes I ran the power wire from one cube to another than spliced that to the green. Then u just ground both cubes to the frame or under the bed somewhere. so the cubes work when my truck is in reverse. I thought about putting them on a switch. I still may do that, but for now I like this.
Moar pics
dat bumper gap
Pulled the 2" block out and added a 3" block. No more backflip look.
Color match tow mirrors or leave current mirrors????
Added blue LEDs to cluster, SRC, and hvac controls. Still need to do window switches and headlight switch. Thanks to miked for installing them
rice as fawk
:cheeky: jk looks good, but srs dfw white led cluster
