Dont even need smaller block IIRC since RCX 6" is block and add a leaf just leave AAL out
Troof
umm let me see,
4ini lift vs 3 in lift. what his bigger 4in or 3in.
jesus christ did you pass the 5th grade?
Do 6" and decrank it, and run smaller block in the rear. Then your angles won't be shitty and you can always go higher cause everybody does eventually.
Hey fucking retard, i said I was told 3 inch body looks bigger bc it lifts the body .
