Will these wheels fit?
Jimmy
Formerly SouthernprideTX
May 8, 2012
1,996
3
North of Houston, Texas
Buddy has an 2007.5 nnbs ext cab 2wd.
He has some Fuel Nutz 20x12 6x135/6x5.5, 4.75 BS
He also has some 33x12.50 tires and plans on getting RCX 5" lift.
I thought lug pattern was 6x139? But ppl at 4wheelparts told him that they should fit.
Will they fit?
5.5" =139mm
The 135mm is a Ford lug pattern. So they should fit Ford, GM full size, Titans/Armada, 6lug Tundras , Tacoma's and 4-runners. I think they will also fit Frontiers, Pathfinders, and Xterras.
Alright, thanks! Earlier when i did a google search, i found some threads on gmfs and they said that 6x135 wouldnt fit without adapters and another thread said they fit but its "ghetto" lol
Wait. I am confused. Are these wheels only the 6 on 135mm bolt pattern?? If so they will NOT fit. I read your post thing these wheels had two bolt patterns, 6 on 135mm and 6 on 5.5in. If they are truly 135mm they will NOT fit.
really people? the wheels are probably double drilled. 6x5.5 is the exact same as 6x139.7 which is what all full size gm vehicles run. 6x135 is ford bolt pattern. so it will work with both applications.
regardless, you will have some serious rubbing with only a 5" lift on a NNBS. i've got the same wheels/tires on my nbs tahoe with my 6" rcd set at 7" and i had to do a good bit of trimming.
This is what my buddy sent me
Didnt even think about them being double drilled,
How much trimming would have to be done to run 33x12.5 on 5" lift? Idk much about nnbs.
You'd be doing a LOT of trimming on just a 5" RCX with 20x12s. If they were x9s or x10s, they'd work no problem, but x12s are wide for that little lift. I'd say a 5" with a smaller spacer or Bilsteins would probably clear them okay, still going to be trimming I bet. Add a 1.5" BL to it, and you'd be getting closer to no trimming.
Will 22x12 -44 offset fit on a 08 gmc 7.5 Rcx lift with 35inch tires?
Sent from my SCH-I545 using Tapatalk
