I picked up some low mileage ( 58,000 to be exact ) 243s off a Z06 this weekend and I had a quick question about milling them before I run them over to Texas Speed & Performance for some head work.
I have been told that milling them .030 will retain the factory compression with the 5.3 dished pistons and I just wanted to confirm that before I spend the money milling them and its be wrong and I lose compression. I have also heard you can mill the .035 but it seems to be hit or miss with the intake seating at the correct angle. I guess some people do it and not have issues, then some do it and the intake leaks. Seems like a crap shoot, any light on this?
Another milling question I have: I am in the process of building a 5.3 block with flat top LS1 pistons. Later down the road, would the .030 be too much of a mill for flat tops? I don't want to run into PTV issues! I was looking for some light on this but it seems that guys with flat tops leave the heads alone, and guys with dished pistons mill them. I want flat tops and a mill for the added compression.
I was also looking at a valve job and wasn't sure if a 3, 5, or 7 angle would be the best route? I am sure I could ask TSP when I take the heads up there but I kind of want to have an idea of what is the best options before I get there and get told otherwise then get hit up for a ton of work.
I will be running these heads with a TBSS intake that I got a few weeks ago that is equipped with NNBS Flex Fuel 36 pound injectors
Few pics for reference.
Thanks!
Thanks!
