I've done some research but haven't had any luck. I'm slowly gathering parts for my next parts go-around. Looking to step up to bigger injectors and can get a set of LS3 42lb injectors for $125. I need to know if these ls3 injectors will work on a TBSS intake on stock 99-02 fuel rails which I'll be modifying. I know I need to change to the ev6 injector connectors which is not big deal. What's the best place to get those?
Should I get the 42lb marine injectors instead?
It's a 2000 half ton with an lq4 with a tbss intake.
