Okay, so anyone with a NBS knows the front valance likes to hang down and get all droopy. Well for us lowered guys this can mean that if we back up and we catch the ground or put it in any bind that it will pull off of the truck. Mine used to do it really bad being @ 6" of drop up front.. well this easy and simple mod not only help keeps it from pulling off so easy, it also keeps it level and not looking droopy on the front. It might be a tiny thing no will will ask about but it really improves the way the front looks...
First things you will need are: Zipties, Drill, Drill Bit (You will need to raise truck, whether on a lift or jack it up alittle to get to where you can work.)
Now: Drill your first hole in the center of the valance directly under the skid plate hole, now drill two to each side of the center under where the skid plate ends. Now drill two holes on each corner of the skid plate itself, finally loop your zipties thru and don't tighten them yet. Now with your hand push valance up until it looks close to level then step back and look, keep tightening until it looks how you want, the two side zipties will be to help give it more stability and help hold it more... now enjoy your work that no one else will notice lol.
Onto the pictures..
Best pic of how it looks that I can get at the moment.. It will help the lowered guys a lot to keep from pulling the valance off.
Onto the pictures..
