things you need:
Phillips screw driver
m6 washers (12 total)
m6-1.00x20mm bolts(if you want them. 4 total)
putty knife or something similar
all in all this took me about ten minutes but I've done this before so set aside a half hour or so
first start out by sticking a putty knife or something else between the plastic cap and pulling it apart. there is a tab on each side
next I loosen all the bolts with a screw gun and I leave them right before they come out. here are the screws
I like to pop off two at a time. meaning the top right and top left and you can fit ur fingers in there for the washers. I get extended bolts but it's up to you. now place three washers on the top behind the metal bracket like this
thread both in partially and repeat process on top left and bottom left bolt. pop on plastic cover and you're done with that mirror. repeat process on other mirror as well.
pass side done. drivers side stock
now both sides done
now both sides done
