Need input on if I need to change out the fuel lines and return line regulator. I have a 2010 Sierra it came stock with a 4.8l flex fuel, I upgraded to the 430hp ls3 and changed the fuel pump to walbro 450, I'm running 60# injectors and a procharger supercharger D1-sc1 with 10# of boost. Motor didn't survive the dyno. So I'm replacing it with the lsx 376 B-15 and I'm not sure if the fuel system is going to be good enough for this setup. Hp I think will be around 550.
