Custom 94 ext cab silverado longbed
LeonMiller94
Mar 25, 2014
57
www.facebook.com
Im doing another custom restoration. Im putting twin 70mm ball bearing turbos on a Ls 5.3 forged steel crank cam and pistons with h-beam rods copper gaskets and titanium lifters and valve springs and im pairing it up to a allison 5spd transmission hooked to a full auminum driveshaft and factory rearend my question is for everyday interstate travel with a 27"tall tire what rearend gear should i run
~jared miller
a pair of 70s will blow that crank and block to shreds, nobody makes/runs titanium lifters or valve springs. and you want to put all of this to a factory rear end through a aluminum drivehshaft?
did someone say titanium lifter and valve springs?
61863d1355122300-random-pictures-thread-only-rule-keep-sfw-fast_and_furious_jesse-jpg
To end this thread ive figured out the running gear with the help of a few forums and performance websites ive figured out the rest of the drive train running an eden pos unit on 3.40 gear ratio
~jared miller
