don't know whose seen this on gmfs but figured id post it over here to. heres some of my bros toys. just gonna copy and paste whats on gmfs.
LMR E85 Reaper ZR1 Corvette Initial Start Up and Walk Around - YouTube
LMR Reaper ZR1 Before and After E85 - YouTube
so he was going with the SLAYER package which is as follows:
C6ZR1 1 7/8 American Racing Stainless Steel Headers
C6Z American Racing X-pipe with high flow cats
02 Extensions
NGK Spark Plugs(Iridium)
MSD 8.5m spark plug wires
Custom Heat Exchanger
Heat Exchanger water pump with connector
C6 ZR1 High Flow Supercharger Air Intake Snout 2009-2013
LS9 Eaton Supercharger Front Cover Assembly
comes with 2.6 supercharger pulley
Air Intake Kit for LS9 Supercharger Front Cover
09/13 Corvette ZR1 Harmonic Balancer Kit
LS3 160* Thermostat
LS3 Comp Cam Kit, Comp custom grind cam shaft, comp Double valve spring kit good for .675 lift, Titanium Retainers(custom for ZR1), Spring Seats, Valve seals, and comp chromoly pushrods
Water pump gaskets, Oil pump inlet tube, front cover, crankshaft front seal
LS9 Crank Bolt
Mild to Wild Exhaust Switch
Lowering Bolt Kit
Mobil One Synthetic Oil
Mobil One Oil Filter
Coolant
Professionally Installed
Forced Induction Dyno Tune
he went with the reaper package instead which is the next step up and has 885bhp, and then added e85 to that.reaper is pretty much the same shit but has some head work and other shit done I believe.
the diesel and the zr1
diesel and the range rover
and the vette of course
and his truck
02 Extensions
LS3 160* Thermostat
LS9 Crank Bolt
Lowering Bolt Kit
Coolant
and his truck
