About a year or so ago, I replaced my alternator pulley with a smaller one to gain a little more amperage at idle (since I had converted my truck to E-fans).
This ended up putting some more slack in the serpentine belt. So much slack that on cold mornings I would sometimes hear the belt squealing until the engine warmed up a bit. I would also hear my belt squeal or chirp a bit on very fast acceleration, mainly when the transmission shifted gears at high RPMs. Fast forward to now....
I just changed my belts and all belt tensioners and the idler puller. I decided to go with the shorter belt that would come on a truck with a 105a alternator. It's 3/4 inch shorter. The shorter belt fits, but the belt tensioner is stretched over basically almost as far as it will stretch. Is this a bad thing? Or will I be ok running it like this?
My neighbor claims I will destroy my belt tensioner. I honestly have no idea if this will hurt anything. I figured it would be better with the belt tighter?
